labview email.
I am using labview 7.1  I  am acquiring data using ni card. iwant to ad dsome new function and it if some alarming condition is occured than an email should be sent to my client using asp.i can check the alarming condition in labview program i also have asp file to send email what i do nt know is how i should inform my web server that labview has detected the condiotion and it shoudl run the my ASP file. any idea iam not using internet tool kit for labview as i do nt have it in labview 7.1.
Message 1 of 31
(7,277 Views)
Do you have to use asp?  I am not familiar with it, but if you can get away with it, LV 7.1 has built in SMTP email vi's.  When an input value is out of range, you can have it send an email.  I attached a simple example.  Only catch is you need access to an SMTP server.  There is also a vi to send an email with attachments.  I use this to send emails when a test fails at work so important long-term tests don't sit unnoticed over the weekend.  Hope this is helpful.
Matt
maat
LV2019
Message 2 of 31
(7,243 Views)
Unfortunately the advent of corporate spam filters is making if harder and harder to send email. The problem is that there have been dozens of additions to the basic smtp protocol and many systems won't accept messages that they interpret as being "malformed" or with header information that is "incomplete". Rather than continually tweaking lv's smtp drivers to get messages through the hoops that corporate IT departments are contantly erecting, I have started using a free smtp activex component from a company called OstroSoft.
It's easy to use and is dependable. Attached is the VI I wrote to talk to their component. You can download the component itself online (do a search on the company name).
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 31
(7,239 Views)
Mike,
You and LV_Pro are everywhere!
That Ostrosoft is pretty neat. I'm going to keep that in my back pocket in case our IT group does shut us down.  They weren't too happy I was making use of the mailserver for our lab, but as of yet it is still "open enough" to use standard SMTP vis.
Matt
maat
LV2019
Message 4 of 31
(7,212 Views)
thanks is there any way to run a  web page inside labview VI
Message 5 of 31
(7,194 Views)
Hey Dost, You can publish your front panel onto the web (if that is what you mean by run a webpage in LabVIEW). Go to Tools>>Web Publishing Tool and from there you can configure a webpage and you can even take control of the front panel through the web browser (right click and request control). Hope this helps, If you have any further questions give me a shout. Best regards, Peter H. Applications Engineer. NIUK.
Message 6 of 31
(7,191 Views)
I am using labview Remote panel option through which an VI can be remotely access. i want to know is there any way i can check the session i mean i want some usere to first login on my  web server IIS then from there they r directed to the VI and i want to pass some information like user Email address to this vI .how can i do this any idea
Message 7 of 31
(7,185 Views)
Thanks iam exactly doing what u just wrote but i want to do a little further i want to do state management so that user first has to logon on my site fromwhere i would maintain a session and than he/she will go to my labview vi.i want to know is there any way that i can use this remote panel with either jsp or asp or any other server side langauage.
Message 8 of 31
(7,171 Views)
when i run the lv7.0 example SMTP vi, it always fail. why the SMTP email send vi doesnot ask me to input "user name" and "password"?
Message 9 of 31
(7,126 Views)
Hard to say, what's the error?
Mike...
LabVIEW Champion
Message 10 of 31
(7,097 Views)
