labview does de-activate licence
Hola, estoy trabajando en un programa que reciba datos por bluetooth desde un dispositivo HC-06, el problema es que al correr el VI el 'visa resourse name' no reconoce ningún puerto por el cual se pueda establecer la comunicación, y no se si sea el programa (por un fallo la paleta de funciones) o por algun problema en la configuracion de la PC. Espero puedan apoyarme.
(2,962 Views)
Most readers will better understand English:
@IsraelCortez wrote:
Hello, I am working on a program that receives data via bluetooth from a HC-06 device, the problem is that when running the VI the 'visa resourse name' does not recognize any port for which communication can be established, and I do not know if either the program (due to a fault in the function palette) or due to some problem in the configuration of the PC. I hope you can support me.
(2,926 Views)
What is "visa resource name" VI? Do you mean "Find Resource" function?
Perhaps post some code?
(2,924 Views)
Thank you wiebe@CARYA.
An HC-06 Bluetooth Serial device needs to be paired with your computer and that should install a "virtual serial port" for the HC-06 before VISA will see it.
Un dispositivo HC-06 Bluetooth Serial debe emparejarse con su computadora y debe instalar un "puerto serie virtual" para el HC-06 antes de que VISA lo vea. (Traductor de google)
=== Engineer Ambiguously ===
(2,916 Views)
