labview cut-off frequency
How  can I decide the cut-off frequency (low and high) in band pass filter?
(5,056 Views)
What function are you trying to use?  Doing a quick search for a bandpass filter and the functions have the cut-off frequencies as inputs.  So I am not sure what you are trying to get at.
(5,041 Views)
That's a pretty ambiguous question.  That's like saying, "How fast should I drive?"  The answer to both questions is, "It depends."
Bill
CLD
(Mid-Level minion.)
(5,035 Views)
(5,032 Views)
A picture without words to explain what it is you are trying to show us doesn't help.
(5,022 Views)
I accidently sent it sorry. My problem is with the cut-off frequencys. I am trying to set it lower than the 500 because my fs is 1000 and with that lower frequency should be lower than 500 and maybe it can be 450 and higher can be 485 right?
Note: I am trying to filtering noise from the sinusoidal source.
Thank you for all of your answers.
(5,015 Views)
You really need to take a course in Signal Theory, and learn about digital and analog signals.
(4,995 Views)
