Relative File Path Syntax
I am trying to use "Read From Spreadsheet File.vi" and am having trouble using relative file paths (as opposed to absolute file paths).
Does this VI support relative file paths and what is the syntax of relative paths? Thanks.
Linus Chung
(21,033 Views)
Hi Linus,
Yes, file VIs support relative file paths. Under the "File I/O" function palette, you can find "Build path" and "Strip path". Use those VIs to build relative file paths.
Also you can use "." (one dots) for the input path and ".." two dots for one path level up, just as you could use them in command prompts.
Attached VI is an example.
(21,034 Views)
hi linus,
can you paste relativepath.vi for labview 7.0? i cant open your 7.1 file.
thanks
timon
(20,835 Views)
Thanks. Very useful for me.
(12,726 Views)
