keep subVi at front
Is there a way of KEEPING a SubVI at front until its finished its job. I need this to be true even if the user accidently presses the Main VI (which would be at the back when Sub Vi is running).
Kas
Message Edited by zerotolerance on 04-05-2010 12:04 AM
Message Edited by zerotolerance on 04-05-2010 12:05 AM
Message 1 of 9
(3,518 Views)
You can use an alt tab to bring the vi back to front of the main vi. You can also use invoke node "bring to front" option.
Message 2 of 9
(3,502 Views)
I don't think I can see the "bring to front" option from an invoke node. I'm wiring VI's reference to the invoke node, but nada.
Kas
Message 3 of 9
(3,494 Views)
Hey forget my above post you can do exactly what you want by using a vi reference and using a property node like this
Use this inside the subvi.
Message 4 of 9
(3,493 Views)
Message 5 of 9
(3,490 Views)
Accepted by zerotolerance
You can use the window behaviour by changing it to "modal"
CTRL+I->Windows appearence (from the drop down ring)->hit the "Customize" boolean and select option "Modal" from
Guru
Guru (CLA)
Message 6 of 9
(3,489 Views)
Window behaviour "model" did it. I usually run my SubVi's through "VI preference". I tried muks idea and that worked just as well.
Thank you both.
Kas
Message Edited by zerotolerance on 04-05-2010 01:16 AM
Message 7 of 9
(3,485 Views)
Its "MODAL" not "MODEL"
Guru
Guru (CLA)
Message 8 of 9
(3,478 Views)
haha. Sorry. Just noticed. :smileyvery-happy:
Thanks again.
Kas
Message 9 of 9
(3,467 Views)
