ip address
Can you post a copy of this code that you are using, which is now generating an error code 60?
Also a description of your network setup would be good:
  • How exactly is your computer connected to your sensor?
  • What is your sensor's IP address?
  • What is your computer's IP address?  Do you have more than one network interface on the machine?
Message 11 of 14
(1,258 Views)
I would imagine that it's probably because another application is also listening on the port. You should be able to run a netstat command in a windows command prompt to find out the name/process ID of applications using the port to check whether or not it's in use.
(blog)
Message 12 of 14
(1,234 Views)
All i know is that the IP addresse is 192.168.0.2 and this is the code.
Message 13 of 14
(1,206 Views)
Is that the IP address of your computer, or of the sensor?  How did you confirm this address?
Can you save the VI for LabVIEW 2013 and reattach?
Message 14 of 14
(1,193 Views)
