07-13-2006 02:20 AM
07-13-2006 06:15 AM
Hello!
Please check out this link since it will most likely solve your issues.
What Do I Do When I Get an Invalid Help File Path Error?
http://digital.ni.com/public.nsf/websearch/1F25EBE7E7A07E91862571110080EA0E?OpenDocument
01-13-2009 12:44 PM
Hi Jimmie,
I am suffering the same problem discussed in this thread. However, when I try to see the link recommended for you I don't have access. It seems that is not working.
Could you help me please!!!!
Héctor.-
01-14-2009 03:03 AM
Hello Héctor!
The KB is archived but you can find the same information in the link below:
Hope this helps!
01-14-2009 04:44 AM
Hi Jimmie,
I have followed the indications from the link and I have solved my problem.
Thanks again,
Héctor.-
01-14-2009 05:24 AM
Hello Héctor!
Could you please be kind and mark my response as a solution to your problem? The ‘Kudos' button on the right in my response since it makes it easier for other people to find a solution to similar issues.
Thanks in advance!
01-15-2009 08:13 AM
Hi Jimmie,
Thanks for your answers. I already have marked in Kudos button.
Now, I have another doubt to solve. I am trying to stop a VI from another VI through VI Server feature. However, I do not want to stop the VI using abort method from VI Server. What I want is to set the value of a variable named stop which is wired to an ended element of a while loop in order to execute a piece of code before stopping the VI target. The problem that I have is that when the sampling period of the VI target is greater than 1seg (more and less), I see that the stop variable in VI target is pressed but the VI is not stopped. The state of execution of the VI target still is "Run top level" and no "Idel".
I have attached the VI target which is very simple "jilTest.vi".
Thanks in advance,
Héctor.-
01-16-2009 03:20 AM
Hello Héctor!
Look at the attached example that is a VI aimed to control the VI you posted here in this thread. Hope it helps!
01-16-2009 03:49 AM
Hi Jimmie,
Could you to attach the example to LabVIEW 8.2.1, please!!!.
Thanks in advance,
Héctor.-
01-16-2009 04:14 AM
Here you have the example saved in 8.2.
