how to make a waveform graph for the Bandwidth by changing the time
Hallo All,
I hope you can help me in this forum.
i made a small program which can calculate the bandwith of the magnitude in fourier domain resulted from the formula ( V(t) = 1/(4*((pi)*a*t)**3/2) * exp(-(x**2+y**2 + z**2)/4*a*t) ) in the time domain. "for particular values for x,y,z,a ".
Now i am interested in making a waveform graph, that shows how the bandwidth changes by changing the time from 0 to 200.  I mean, the time should be the x-achse in this waveform graph and the bandwidth should be the y-achse.  How can i do it?
i attached my small program.
Thanks alot in advance
(2,923 Views)
Hi Oliver,
one thing first: please make sure to always time your loops. Otherwise you will swamp your CPU (a 50ms waiting period would work very well).
Unfortunately, I am not entirely sure what you are trying to achieve. You receive the value for bandwidth and want to display it in another graph. What exactly would be the x-axis? The time from 0 to 200? Could you give an example?
Thanks and best regards,
Peter
Peter A.
Field Sales Engineer, NI Germany
(2,882 Views)
Hallo PaSB,
i already solved the problem. however many thanks for your Hints.
regards..
(2,842 Views)
Hi Oliver,
Thanks for your feedback. Always feel free to post questions to our forums!
Peter
Peter A.
(2,839 Views)
