intel core i7 5820K
hello,
just a  a quick question
Does Labview support a 6-core processor like the intel Core i7-5820K ?
thank you
Message 1 of 9
(5,245 Views)
Accepted by ouadji
Just a quick answer: Yes.
LabVIEW supports multi-cored processors.
(blog)
Message 2 of 9
(5,229 Views)
thank you Sam_Sharp,
Is there a limitation of the maximum number of cores ?
Message 3 of 9
(5,226 Views)
Not that I'm aware of. I would certainly expect any currently available Intel/AMD CPU to be supported.
(blog)
Message 4 of 9
(5,221 Views)
ok, perfect, thank you very much.
Message 5 of 9
(5,216 Views)
I would guess cores arent an issue, but threads might be:
http://digital.ni.com/public.nsf/allkb/84ECA015AA496B23862565BC006C0F19
sounds like a 6 core processor would have a grand total of 120 or so threads. On the other hand, 120 threads doesn't sound like an issue for windows either, so in short ^^yes, probably no problem.
Message 6 of 9
(5,194 Views)
that said, better still would be to have the answer of a labview user that has a computer with more than 4 cores.
Does someone use labview with a 6 or 8-core processor ?
Message 7 of 9
(5,159 Views)
Both my laptop and computer at home have 8 cores, and i know Altenbach have used an Opteron with 16 or 32 cores.
The real question is how well you can write a program to use all these cores.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 9
(5,153 Views)
Both my laptop and computer at home have 8 cores...
Altenbach have used an Opteron with 16 or 32 cores...
Now, this is no longer an assumption, it's a certainty.
thank you Yamaeda.
Message 9 of 9
(5,140 Views)
