instant time
how to capture instant time of plugging a wire & viceversa using labview code.
(2,852 Views)
Where does the wire connect to and how is LabVIEW supposed to know about it?
Are you connecting to a DAQ device, for example?
More details please!
(2,850 Views)
actually wire is a multidrop cable which is used to connect different devices .. in my set up it is connecting a profi-master and profi-slave
when i remove the connector from slave & i need to capture the time by labview code also
when i again plug-in the connector to slave then i need to capture the time by labview code .
(2,792 Views)
You really need to work on formatting your questions so we don't all waste our time guessing what you want. Be specific.
I assume you're talking about the PROFIBUS communication cables???   I've never used it but a quick search indicated there are built in diagnostics that can monitor the connection.  Have you looked into that?  How accurate does the timing need to be?  It this a RT or FPGA system?
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,775 Views)
