Hii NI Forum Members,
I would like to plot the XY graph (2 vertical axes with pressure and temp and 1 horizontal axis time),in parallel the values are generated in excel sheet with 3 columns and with multiple rows.
Hence,How can i import the excel sheet columns and rows and plot the generated excel sheet values in XY graph of LabVIEW
Waiting for your vauable reply,
Raj
First save Excel data as a .txt (Tab Delimited), then import with Read From Spreadsheet.vi
http://zone.ni.com/reference/en-XX/help/371361J-01/glang/read_from_spreadsheet_file/
Kind regards
Why don't you use the Report Generation toolkit? It has plenty of Excel-related vis. You can import data from any of the worksheets and after garbaging the non-number data you can convert it to numbers as well (or if you do not have any string-cells, only numbers you can import it as a 2d numeric array by changing the array constant). If you do not wire any input to the report generation, it does not overwrite your data. (The excel sheet goes to template.)
I just tried it with an xlsx file and worked fine.
After importing the data you can manipulate it the way you want it, for example plotting it.
