imaq error
Can anybody help me solve the error that occured while executing the attached program code.
Error -1074395992 occurred at IMAQ ReadFile
Possible reason(s):
IMAQ Vision: File access denied.
Thank you.
Message 1 of 9
(5,503 Views)
Check you path, this usually happens when you give a folder path instead of a file path.
In your example I think the way you deal with path is a bit messy, you need a reference path for image and maybe subdirectories for temp images, main image and another one to maybe save images.
Hope this helps
Epictetus
Antoine Chalons
Message 2 of 9
(5,497 Views)
Thank you for your kind response.
I did the modification you mentioned. but now itsays "Error -1074395997 occurred at IMAQ ReadImageAndVisionInfo.
Possible reason(s):
IMAQ Vision: Invalid parameter."
Message 3 of 9
(5,490 Views)
Well there are only 2 parameters you feed into that VI the file path and the image buffer, one of the two has a problem, I bet it's the path.
Good luck
Epictetus
Antoine Chalons
Message 4 of 9
(5,485 Views)
Hello ymadhuri
Can you pls uplaod the vi in LV2011 format so that i can have a look?
thnx
Nghtcwrlr
Message 5 of 9
(5,474 Views)
I attached the 2011 version of the vi.
Message 6 of 9
(5,462 Views)
The actual program is in the following attachment. The previous program attached is used to perform the same function but with input images read from a folder. But the actual rquirement is acquiring images directly from a camera.
I am using my laptop webcamera.
When I run the "Process acquired images" individually it is working fine but when I run it inside the main Vi ,the "Processed image" on the front panel is not showing the expected image. Instead it is displaying the "Acquired image" from "Process acquired image" sub vi.
Can you please help me rectify the problem.
Thank you.
Message 7 of 9
(5,457 Views)
Hello Ymadhuri...
I guess it has something to do with path. Check your control IMAGE PATH. When i click the icon there comes a window to save the image and not to load the image. I guess you should change it so that IMAQ Read can read teh file
Nghtcwrlr
Message 8 of 9
(5,431 Views)
The error you mentioned. actually that terminal comes from the front panel image display of "process acquired image vi"
So I think it should be able to display the picture in the main vi. But i  tried to follow your correction and placed the picture display after imaq read file, still no luck.
Message 9 of 9
(5,427 Views)
