02-20-2013 09:51 AM
I'm using Excel for the HMI of a data logging application. I would like to have several different worksheets depending on the test being performed. I can write the data to any sheet by making it the active sheet but I need to be able to allow the operator to chose which sheet they want active while data continues to update in the non-active worksheet. I am using LV8.5 and have the report generation toolkit but don't see how to accomplish what I need. Thanks, Mike
02-20-2013
12:54 PM
- last edited on
02-06-2026
05:10 PM
by
Content Cleaner
Wow ... Excel as an HMI !
Do really mean that the user will be interacting with the machine through Excel? Or do you just intend to output data to Excel?
Anyways, I think you want to use Active-X Automation in order to interface with Excel. Here is an example. [Link removed; example code no longer available.]
02-20-2013 01:09 PM
Thanks for the tip on active X, I'll give it a go. Using Excel only to display data that is generated in a loop using yokogawa dm100's and the excel toolkit. Made sense to me as the data needed to be display in column and rows and updated frequently (100 channels, 1 second interval). What little control will be needed will be done in LV. Regards, Mike
02-20-2013 03:56 PM
Have you ever seen the Multicolumn Listbox?
It's a frontpanel control/indicator and it can display data in cloumns and rows.
And you can have a Tab Control with multible tabs, each with a Multicolumn Listbox. No Excel needed.
02-21-2013 09:04 AM
Thanks for the suggestion. Yes, I am familiar with it. Have also used the table control frequently in the past. Just wanted to do something different this time.
