i want to split a string after every two characters into a string can somebody help me.?
string to array
Message 1 of 20
(8,002 Views)
string to array
Message 2 of 20
(7,993 Views)
Hi nouman,
what have you tried so far?
Did you use StringSubset? In a loop to get parts of your input string? That would be the most forward approach…
Here's a different approach:
P.S.: no need to post twice when you can edit your own message!
Message 3 of 20
(7,992 Views)
yeah i tried string subset in a loop but i didnt got my desired results.
the thing i am trying is that the first two characters of string to be placed at index 0 of array the next two on index 1 and so on.
Message 4 of 20
(7,980 Views)
Here's another take on the solution.
Here are the results that it provides:
Is this what you are going for?
Wes Pierce
Principal Engineer
Pierce Controls
Message 5 of 20
(7,973 Views)
thanx both of them works for me one converts in a row second one in a column
Message 6 of 20
(7,960 Views)
They actually give the exact same result.  I don't know what you mean by a row vs. a column.  They both give 1-D arrays.  Whether it looks like a row or a column is just a function of how you drag out the array indicator to show multiple elements.
Message 7 of 20
(7,948 Views)
string 1,2,3,4 are of 32 bits each and i want them to convert them into a 4*4 matrix but i am only getting the first row not a 4*4 matrix at the end. what am i doing wrong.?
Message 8 of 20
(7,934 Views)
Attach your code as a VI with your data saved as default in the strings.
It seems wierd that you are doing a conversion from binary to hex.
If you want a 4x4 array, then reshape array should use 4 as a constant rather than a 2.
Message 9 of 20
(7,931 Views)
i want two characters at 1*1 position of matrix so first reshape array is used to make a array having two characters at every index. i am getting an array having 2 characters at every index after for loop then i want to convert it into a 4*4 matrix but i am getting only first row.
Message 10 of 20
(7,917 Views)
