Draw Arc Problem
I'm trying to draw an arc from my first point to my second point from a center point. I've attached the vi that I have been working with. What I need it to do is draw an arc from my start point to my end point in a counter clockwise direction. Can someone help me with this one?
(4,918 Views)
forgot the attachment!
(4,917 Views)
Joe John,
Have you tried using the actual Draw Arc.VI included on the tools pallette at Programming»Graphics & Sound»Picture Functions?  What are you trying to draw this arc to?
Sincerely,
Jason Daming
http://www.ni.com/support
(4,875 Views)
Your problem seems overdetermined, unless I don't understand your definition of arc. Can you show a drawing with the start-, center-, end- points in relation to the desired arc?
For example shouldn't the start-center distance be equal to the end-center distance?
Your default data have the end and center at the same position, giving you an arc of radius zero. You get an arc by providing better inputs.
(4,867 Views)
I considered it underdetermined, I could draw multiple arcs which I consider to be segments of an ellipse.  I can vary the focal distance and inclination of the major axis.
(4,864 Views)
hi joe,
  TO get the arc in counter clock wise,wire a negative arc length to draw arc picture vi.
Thanks and regards,
srikrishnaNF
Srikrishna
(4,845 Views)
(4,318 Views)
