how to write or which block is used to write (e^-j*theta)
How to write or which block is used to write (e^-j*theta). I want to add the block of (e^-j*theta) in my model. I have attached my model showing error. plz see to it. And I am unable to send my labview model here.
Message 1 of 20
(7,092 Views)
That subVI seesm to be rather specific, creating a 1D array of unknown size from a single DBL scalar. I don't you need it.
Most operations seem to involve complex data, so the regular exponentiation will actually do the right thing that you would expect. Have you tried?
Message 2 of 20
(7,087 Views)
yes , its not working. Will I will give you my VI. plz send me your email id.
Message 3 of 20
(7,079 Views)
Sorry, I typically don't do private help and I am pretty busy at the moment. Post the zipped set of vis here to give everyone a chance to help. Maybe you could also try to contact the authors of the paper.
Message 4 of 20
(7,063 Views)
file is attached here. see to it.
Message 5 of 20
(7,055 Views)
Your data is DBL, not complex (CDB). You need to fix it upstream.
Message 6 of 20
(7,048 Views)
how sir?? Please tell me
Message 7 of 20
(7,042 Views)
Well, I would probably create a second signal 90 degrees out of phase and combine it into a complex array.
This paper is way too opaque to tell anything, e.g. what are the simulation parameters (express VIs are mostly invisible from a code picture). What is the sigificance of the "12" diagram constant? How big is the complex array coming out of that subVI. (You can see from the coercion dot and the subsequent processing that the output is complex).
The author list of the paper contains all their e-mail addresses. Why don't you ask them???
Message 8 of 20
(7,034 Views)
I think u havent read anything in the paper. Everything is written in the paper . All about the signal which they have taken, no. of samples everything.
Message 9 of 20
(7,015 Views)
Exactly. Why should I read it?
Message 10 of 20
(7,008 Views)
