how to programmatically detect a dirty dot in labview vi using labview scripting
hi folks,
I'm trying to write a code which goes through a few VIs and check if they have a dirty dot using labview scripting but having a tough time trying to find a way to do this. is there a way i can do this? any help is greatly appreciated!
-S
Message 1 of 8
(6,834 Views)
What is dirty dot? You mean coercion dot?
uday
Message 2 of 8
(6,832 Views)
when the code isnt saved or compiled, the asterisk that appears next to the vi name.
Message 3 of 8
(6,830 Views)
If you are having Labview 2009 or 10:
http://digital.ni.com/public.nsf/allkb/D4032A485C9F18C1862576D6007681F4
uday
Message 4 of 8
(6,824 Views)
Uday,
I have labview 2013 and i am looking to write code that goes through all my VIs and reports if the code has unsaved changes. i want to know if it can done through labview scripting. more like a vi analyser kind of a thing but i need to look through VIs in a certain folder.
Message 5 of 8
(6,821 Views)
Accepted by topic author socalscouser
Message 6 of 8
(6,809 Views)
VI property node, not even a scripting property called Modification >>  VIModificationsBit Set
I haven't used it myself,  but searching the properties, that looks like the right one.
Message 7 of 8
(6,807 Views)
thanks Mathew! this was helpful.
Message 8 of 8
(6,789 Views)
