how to send decimal data using VISA from serial port?
 Thank you for reply.
I modified as i attached. But still i am getting continuos data like 1 1 1 1 1 1 1
i given mechanical action of switch until released.
Message 11 of 17
(1,167 Views)
Did you attach the correct file?  This looks exactly like the snippet you posted earlier...
Bill
CLD
(Mid-Level minion.)
Message 12 of 17
(1,151 Views)
Every iteration of the while loop you check the enum and output 1. Instead of checking only the enum, compare it to the previous value of the enum and output 1 only if the value is different. See attached for an example.
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Message 13 of 17
(1,146 Views)
I tried with shift registers but i am not gettign correct output.
Need a program to send visa write only 1 byte after sending 1 byte the VI has to wait for user input.
Message 14 of 17
(1,136 Views)
see attached. I added diagram disable structures so I could check it easily on my computer, for cases bulb1 on and bulb 1 off (not the rest). It outputs the correct output as I understand it. can you be more specific as to waht the problem is?
― Terry Pratchett
Message 15 of 17
(1,132 Views)
Then use an Event Structure.
GCentral
Message 16 of 17
(1,125 Views)
Thank you
Message 17 of 17
(1,118 Views)
