how to save daq data-in(from 2 channels) in 2-D arrey?
Hiiiiii my friends.
i have a analog system .the output voltage of system changes during changing it's angle or direction. i want to save 2 features of it(output voltage and output angle) in 2-D arrey that shows me output angle and  it's related output voltage toward each other.so after finishing my test i should have data in 2 columns.column1:angles column2: related voltage to each angle.
after that i want to draw it's graph in labview(Voltage-Angle).
please help me in this way (i'm a biginner in this way so i'd  be glad if you explain me in detail.....)
,thanxxxx a lot
Message 1 of 34
(3,898 Views)
For saving the data, just use the Write To Spreadsheet File.
For writing to a graph, use Index Array to get the two colums and then use Bundle to create a cluster out of the two 1D arrays.  Wire this cluster up to your graph.
GCentral
Message 2 of 34
(3,891 Views)
thnx ...
I attached my created vi to show you how much i understand from  what you mentioned.
I have  problem in saving data in any path i choose!
why my vi don't work?
thnx for your good answers...
Message 3 of 34
(3,877 Views)
Why are you using a Build Matrix?  And where is the 2D Array you claimed you had?  You just have a single value coming in as an input.  Where are the measured Angle and Voltage measurements?
GCentral
Message 4 of 34
(3,867 Views)
i sopposed  that i want to save data(X)and its square(X^2). in 2-D array. beacause it is easier for me to write and correct the Vi quickly. so now my problem beacome more simple .
 When i use Write 2 Spreadsheet file it needs  array as input! i wired 2-D array and now i need to make 2-D array!? so i used appended array to make 2 different array as 2-D array.
where is my problems?
excuse me , can you explain more and in a simple way?
thnx for your attention.
Message 5 of 34
(3,864 Views)
GCentral
Message 6 of 34
(3,853 Views)
Message 7 of 34
(3,841 Views)
Excuse me , I don't understand what changes you made?!
Message 8 of 34
(3,837 Views)
Hello
I'm waiting for your answers...please help me to solve my problem.
Message 9 of 34
(3,815 Views)
Update...
Message 10 of 34
(3,784 Views)
