ā05-09-2007 03:01 AM
ā05-09-2007 03:57 AM
ā05-09-2007 04:02 AM
Take a look at this link:
http://zone.ni.com/devzone/cda/epd/p/id/3409
I found this library interesting even if I didn't use it.
Bye
ā05-09-2007 04:03 AM - edited ā05-09-2007 04:03 AM
Message Edited by craigc on 05-09-2007 04:04 AM
ā05-09-2007 04:27 AM
Hi Jorge,
Thanks for your reply.I do not have report genration tool kit. Is their any other way to do this?
Basically I want to read the data from excel sheet to plot the graph. Graph will be having any number of column and row from the excel sheet. So I thought that if i read the excel file in array and then select column (let's say 2,4,6) and rows (let's 50 to 100) to plot the graph. Do you have any idea how to do this?
Thanks & Regards:-
Mike
ā05-09-2007 04:34 AM
Hi Craigc,
Thanks for your reply. I am storing data in the excel sheet which I will be using to plot the graph. So is their any inpact of converting file to .csv file in terms of writing data to the file.
My second query is that I want to use data which I have collected in array to plot the graph. The user will select the column numbers and number of rows to be plottted. How I can extract data according to user input?
Thanks in advance:-
Mike
ā05-09-2007 04:44 AM
ā05-09-2007 05:42 AM
Hi Craigc,
I have observed noting on the graph. I try to change to Column Index no(A),Column Index no(B) ,row start no. number of rows. But graph has not come. Will it be possible for you to provide me with sample .csv file so that I can observe the graph and do some analysis. I am looking for positive response from you.
Mike.
ā05-09-2007 09:11 AM - edited ā05-09-2007 09:11 AM
ā05-09-2007 09:22 AM
@smercurio_fc wrote:
This seems to be a continuation of this thead.Message Edited by smercurio_fc on 05-09-2007 09:11 AM
