how to programmatically clear the chart
Good morning
I have doubt in clearing a chart programmatically
I need to display the the values in chart and clear the chart,again i need to display in the next cycle
I am able to display values and clear programmatically(passing some empty array values), but not able to diplay values in next cycle
Pls give me some suggestions
Message 1 of 8
(3,960 Views)
Your way of working sounds good to me Smiley Happy
Send data to chart to display it
Send empty array to chart to clear it
Send new data to chart to display it
Maybe you didn't program it well Smiley Sad
Can you post your VI so that we can have a look at it?
Message 2 of 8
(3,958 Views)
Thanks Alain
I have atached my eg program
Message 3 of 8
(3,951 Views)
Since you send only one point to the chart, you can't display a line, so change the plot style of the plot to points or keep the line style plot but generate multiple points using a for loop with for example 15 iterations.
Both ways will do, with the first one you will see a unique point every 2 seconds, with the second one you will see a new line every two seconds.
You don't need to wire the dimesion size connector of the Initialize array vi.
Message 4 of 8
(3,946 Views)
Thanks Alain
Message 5 of 8
(3,935 Views)
One more question
If i want clear the chart only after the time scale reached 100, how can i do this
Message 6 of 8
(3,925 Views)
Consider changing the ADVANCED - UPDATE MODE to SCOPE chart.
That will clear automatically when your data gets to the right side, and start over.
 Otherwise, clear it anytime you like by sending an empty array of points to your chart's HISTORY DATA property.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 7 of 8
(3,921 Views)
Thanks Steve
Message 8 of 8
(3,913 Views)
