06-26-2009 05:23 AM
I want to test my fuzzy control and check the I/O characteristics field of my controller.
I could not find the map of my controller.
my LabVIEW version is 8.6.1.
Thanx
06-26-2009 12:46 PM
Hello Sararahimi,
I believe what you are looking for can be found in the Fuzzy Logic Controller Design window. In this window select the Test menu item then I/O - Characteristics.
I hope this helps, let us know if this is not what you're looking for.
Angela M
06-29-2009 04:57 AM
In this part I cannot see the map I mean IO characteristics field.
would you take a look at "Fuzzy logic for G toolkit refrence manual"
http://www.ni.com/pdf/manuals/321511a.pdf
figure 3-18 page 66 please.
Thanx
06-30-2009 07:26 AM
Hello Sararahimi,
I do not think that the plot that you are looking for is available. The Fuzzy Logic implementation allows for up to 4 inputs, so I am not sure how that would be presented in the same graphical form as the dual input plots shown. Only the 2D view is available.
Angela M
Product Support Engineer
07-01-2009 09:21 AM
My controller has 2 inputs and 1 output and I really need a map in 3 dimension to test my controller.
there must be an approach to find that map.
I was wondering if you could help me to find the map which is mentioned in fuzzy logic reference manual.
How they could print out that map.
Tanx
07-10-2009 07:28 AM
There is not a built in function, but if you only have 2 inputs and 1 output you can certainly plot this data on a 3d graph. You can read in your fuzzy controller then create 2 for loops, one nested within the other. In each of these vary input 1 and input 2 along the range that you are interested in and pass those values to the fuzzy logic controller. You can then pass your input 1 and input 2 arrays along with the matrix of results (Z) to the 3D surface plot and you should see the information you are looking for.
Hope this helps,
Angela M
