how to multiply all the elements in an array by negative one
HI
  I have a 1D numeric array, which I want to multiply each element of the array by negative one.  How would I do that?
(4,715 Views)
Accepted by topic author fghfghgfhfhg
You have two options. Top option if you just always want to negate. Bottom if you might want to multiple by something else.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,709 Views)
Well...you'd use negate function...that's it it has one input and one output.
Also you could wire it to a multiple function, with a constant of -1.  If you aren't very experience with LabVIEW feel free to try some free training.
https://decibel.ni.com/content/docs/DOC-40451
(4,706 Views)
Thanks!
(4,690 Views)
