how to multiply all the elements in an array by negative one
HI
  I have a 1D numeric array, which I want to multiply each element of the array by negative one.  How would I do that?
(4,724 Views)
Accepted by fghfghgfhfhg
You have two options. Top option if you just always want to negate. Bottom if you might want to multiple by something else.
Cheers
(4,718 Views)
Well...you'd use negate function...that's it it has one input and one output.
Also you could wire it to a multiple function, with a constant of -1.  If you aren't very experience with LabVIEW feel free to try some free training.
https://decibel.ni.com/content/docs/DOC-40451
(4,715 Views)
Thanks!
(4,699 Views)
