how to increase buffer size
Hi I would like to ask how do I increase the buffer size?
My problem is that the generation cannot be started,
because the buffer size is too small by the way I am using DAQ Assistant.
Selected Buffer Size: 1
Minumum Required Buffer Size: 2
so how do I solve it?
Chris
(5,659 Views)
Accepted by christopher88
Hello Chris, Can I ask what hardware you are using. At present the DAQ Assistant in your example code is set up to perform continues Acquisition and as a result expects a dynamic data type. This can be seen by the small red dot know as a coercion dot and is shown when LabVIEW has to convert the data to another type. There are couple options you can try to fix this.
1) Change the Acquisition type to "1 sample (On Demand)" in the DAQ Assistant this will write your input value to the cDAQ with each iteration of the while loop
2) Change you input data type to a wave form
Here are set of articles that you might find helpful http://zone.ni.com/devzone/cda/tut/p/id/5438
Hope this is helpful
Philip
Philip
Applications Engineer
UK Branch
===If this fixes your problem, mark as solution!===
(5,640 Views)
Hello Philip,
Thanks for your help. I was able to get it done.
Chris
(5,614 Views)
