Data type error
I got an unusual error. The type of data is the same, but I got the following.
(1,645 Views)
Look up XY graph in the example finder and you'll find several ways of combining data to make a graph.  What you did isn't one of them.
What are you trying to do with bundling a 0 and an array into a cluster?  Then building that odd cluster into an array?
Are you just trying to make sure your data starts at 0,2?
(1,638 Views)
I think you should be using Build Waveform, not a build cluster.
With Build Waveform you can set a 0 for T0, and a dT, and an array of data...
Also see HowtoUsetheBuildWaveformFunctionTutorial.pdf.
(1,574 Views)
