how to call subvi Asynchronously with version 8.6
With new version 2011, labview has a function of Start Asynchronous Call, but version 8.6 does not have it.
I would like to call subvi, but not waiting for subvi to finish before excute the next step in main vi.
An asynchronous call to a subVI starts execution of the subVI while allowing data flow to continue in the calling VI.
Anybody can help on how to realize this in version  8.6.
Message 1 of 8
(3,688 Views)
You simply need to call it dynamically the old fashioned way:
Open a VI reference and run it using the run VI method. Make "wait until done" false.
Message 2 of 8
(3,683 Views)
Thanks for helpl. I am still very confused about this. how to open that run vi method?
can you give me a simple example including Open VI Reference Function, call reference by node and this run vi method.
Yihan
Message 3 of 8
(3,672 Views)
Yihan
THe code for this Nugget should serve as an example.
Ben
Message 4 of 8
(3,666 Views)
Hi Ben,
I attached one sub vi and one main vi here.  It is very simple example.
I want to main vi stops before subvi. But it does not work. Can you take a look?
If I remove the run vi session, just connect the open vi reference to call reference node, it works. The problem is when I inserting the run vi method in between, something is wrong.
yihan
Message 5 of 8
(3,660 Views)
Did you look at the example I offered?
I typically don't look at posted VIs (my public machine has LV 7.1 and earlier) but I will look at jpgs.
Ben
Message 6 of 8
(3,651 Views)
Accepted by topic author bozeman
make case 0 look like this
"Should be" isn't "Is" -Jay
Message 7 of 8
(3,648 Views)
works!!!!
thanks so much.
one more question, after Open VI Reference Function , i need to link type specifier vi refnum,  I was tyring to creat a constant from type specifier vi refnum terminal , and then select the subvi , but it does not work. I did your way, just simply link the Static VI Reference Function to type specifier vi refnum, then it works. Can you explian it? Thanks again!!!!
big help!!!!
Message 8 of 8
(3,643 Views)
