how to add a video option to capture image
Message 21 of 54
(2,213 Views)
is this max no: the same as com or srl no of the port used. I have tried the above method, but could not find. Am using a filter and a camera  as input and they are given to two difft ports of the laptop.
Message 22 of 54
(2,203 Views)
Solved?
Message 23 of 54
(2,203 Views)
Can you expand the devices and interface tab and post the screen shot of the same?
Message 24 of 54
(2,201 Views)
Devices and Interfaces
What is Devices and Interfaces?
The Devices and Interfaces category lists installed and detected CAN, DAQ, FieldPoint Serial Controllers, GPIB, IMAQ, IVI, Motion, VISA, and VXI hardware.
If you do not see your devices...
 You have not refreshed the configuration tree.
Press <F5> or choose View»Refresh.
 Your device may not be Windows Plug and Play compatible
View the configuration help file for your device from the Help»Help Topics menu or the instructions below for additional information about adding these types of devices.
 MAX does not support your current driver version
If your devices use the following driver versions, your device may not automatically appear in the MAX configuration tree.
  • FlexMotion 4.5
  • IVI Engine 1.52
  • NI-488.2 1.0 for USB-A
  • NI-DAQ 6.5, 6.6, 6.7
  • NI-IMAQ 2.2
  • ValueMotion 4.3
To update MAX to support these drivers, select
Tools»Install legacy driver support
What do you want to do?
 Configure an existing device
To configure an existing National Instruments device, right-click the channel name in the configuration tree and select Properties, click the Properties button in the toolbar, or adjust the properties in the item view, depending on your software.
 Add a non-Plug and Play or remote DAQ device
Some devices are not Windows Plug and Play compatible, so they do not automatically appear in the Devices and Interfaces list. Other devices may reside in another computer on your network. To add non-Plug and Play or remote DAQ devices, right-click Devices and Interfaces in the configuration tree and select Create New. Complete the wizard.
If you still do not see your installed device, refer to the getting started information included with your hardware and to the MAX product-specific help (Help»Help Topics) to verify that your device is properly installed and for configuration information. If you are certain that your device is correctly installed, visit the support Web site for your device:
 CAN
 DAQ
 FieldPoint
 GPIB
 IMAQ
 IVI
 Modular Instruments
 Motion
 NI Switch Executive
 VISA
 VXI
For more information about using your NI product in MAX, refer to your product-specific help, located on the Help»Help Topics menu item. You can also access NI product help from within MAX help, which you can launch from the Help menu or by pressing <F1>.
Message 25 of 54
(2,193 Views)
I did not ask you give me details reagrding devices and interfaces. You see the above image? Do you have MAX installed? If so can you see the above screen when you open max? Now click on the tab shown above. You will see the interface name. Now if you have difficulty i asked to you to take a printscreen after expanding (Clicking the above mentioned tab in the picture).
Clear????
Message 26 of 54
(2,184 Views)
Message 27 of 54
(2,171 Views)
awaiting ur help
Message 28 of 54
(2,148 Views)
Have you connected the camera?Installed the drivers?Loaded the ICD file?
My suggestion would be to start from the fundamentals and start reading documentation before you start image capture.
Message Edited by muks on 09-17-2009 04:55 PM
Message 29 of 54
(2,140 Views)
the filter is connected to com4 and camera to com 5.It is showing one more port LTP1.
I have sent screen shot of  my personal laptop am using rt now. Project is done in lab laptop.
It would be gr8 if anyone is able to rectify my pblm.
Message 30 of 54
(2,122 Views)
