how to add a video option to capture image
Thanx for the help.. I have tried this..but it is showing error with the close function.
Message 11 of 54
(2,560 Views)
What is the error?
Message 12 of 54
(2,558 Views)
Have you checked whether you are feeding the proper interface name (img 0 or img 1.......)
Message 13 of 54
(2,557 Views)
it is giving the error " error: 1074397163 occured at clean up module."
Message 14 of 54
(2,554 Views)
Message 15 of 54
(2,549 Views)
gave the name img0
Message 16 of 54
(2,546 Views)
I was right after all
While running an IMAQ-Vision example in LabVIEW 5.1, I see this message: Error -1074397163 occurred in Cleanup module.
This error is generated when the IMAQ Init VI is called with an incorrect interface name. In MAX, the NI-IMAQ driver assigns an interface name to each IMAQ board in your computer, starting with img0, then img1, etc., in the order in which the boards are installed. If for example, MAX has img1 set for your interface and then in your code you call the IMAQ Init VI with the interface name img0, it will give you this error.
Message 17 of 54
(2,545 Views)
gave the name img0
It is not something you give. Check with max whether it is 1 or 2 or what it is
Message 18 of 54
(2,544 Views)
I am new to the software and in the prelim stage  Can u tell me how to find the max no:
Message 19 of 54
(2,533 Views)
Max = Measurement & Automation Explorer.
Message 20 of 54
(2,523 Views)
