how do I write elapsed time to build array in only seconds?
Hi everyone,
I am able to use "elapsed time" to send a time stamp to "build array" by using the "elapsed time to text" output.  But after 59 seconds it then gives one minute.  In the excel file it is as follows:
0  00:00:59
0  00:01:00
0  00:01:01
I would like to to continue to 60, 61 seconds and so fourth.  When i try to connect a different subvi it gives me a connection error.  Any help would be greatly appreciated?
Thank you,
Feras
(3,832 Views)
Can you post a VI so we can see how you are doing it now?  Are you writing it using a string array?  Are you really making an Excel file or are you using Write to Spreadsheet file to create a text file that is imported into Excel?
(3,817 Views)
Accepted by topic author frabie
I assume this is the Express VI, you could use the Elapsed time (s) output instead to get the number of elapsed seconds.  If you want a string, use the Format Into String VI, otherwise build an array of DBL to append to the rest of your data.
(3,813 Views)
Here is the attachment.  Thanks for the help!
(3,788 Views)
You've been given the answer, why don't you try it?
One comment about your code. Do not wire up the N terminal of a for loop when you are autoindexing some array inputs.
(3,784 Views)
I am currently working on the code but decided to go ahead an attach it as asked.  But thank you for your concern.
(3,779 Views)
Thanks guys.  I used the formatt to string array and it worked fine.
(3,767 Views)
