how do I modify the palette to go straight to the Programming menu in LV8.5?
I've seen variations of this question asked, but I'm not seeing the answer I'd like to see.
On the back panel, I want to right-click and see everything available in the "Programming" submenu.  (Kinda like it used to be in the old days of LV.)  I don't want to right-click and choose "Programming" -- I want to right-click and see "Structures", "Array", "Class, Cluster, & Variant", ...
I've seen other posts which explain how to pin the menu and select Change Visible Categories.  I can make it so that "Programming" is the only icon when I first right-click, but that's not what I'm trying to do -- I want to see everything in "Programming" the first time I right click.
I'd also like to do the same thing on the front panel -- jump straight to the Modern subpanel.
Help?  Thanks.
(3,275 Views)
Accepted by topic author tdurand
tdurand wrote:
On the back panel, ...
We affectionately call it the block diagram. Smiley Wink
When I right-click I see the Programming palette already shown. I have all categories visible and I also have the "Format" set to "Category (Icons and Text)" in the LabVIEW Options (also accessible from the "View This Palette As" menu item when pinned. I don't recall doing anything beyond that.
(3,264 Views)
Thanks!  Worked for the front block diagram also...  Smiley Wink  If there's a "front" panel, shouldn't there be a ....
(3,249 Views)
According to NI. "LabVIEW displays two windows: the front panel window and the block diagram window."  Quoted from 'Getting started with LabVIEW' page 1-4. Smiley Wink
Message Edited by GovBob on 05-12-2009 02:22 PM
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,224 Views)
