how convert degree to meter?
Hi
After plenty of time to seek, I haven't still found the way for convert degree to meter,
I would to compare the distance between two points on my map, it works and it shows  me the distance in degree but  it would be better to have  the distance in meter
thanks
paco
(16,526 Views)
Hi pacotisme,
Common units of length in the International System of Units (SI) are:
For better understanding will you please attach your VI?
Thanks as kudos only:)
(16,516 Views)
My guess: He is referring to earth coordinates.
(16,511 Views)
Yes I guess the same. You can try this link and try to find out the formula. ( I got it by googling the web 🙂 )
(16,508 Views)
Have a look at wikipedia, geographic coordinate system
There is a section "Expressing latitude and longitude as linear units" which tells you how to convert your degrees.
Christian
(16,505 Views)
yes it's about coordinate
it's the entrance I reade some cordinate with latitude et and longitude , but I would like distance a the end in meter
(16,500 Views)
