If I shake windows of VI's, does not run the code.
I have many VIs called from a VI and thus run in parallel, a VI has a DLL that allows me to communicate via CAN. If I minimize and maximize windows to be changing the VI's or I shake the window, the communication CAN be lost for a moment (And it breaks my comunication system).
I use windows XP.
Some solution? Is this normal?
Message 1 of 8
(3,513 Views)
I am not good with CAN communication but I am giving my opinion by keeping TCP/IP. So what happens when you shake the window is your OS will take time to handle the events and that will be running faster eventhough if it runs for a very short duration ( Like running a while loop without delay ). So your OS will not be able to service the task for the TCP/IP for that time and that may give a break in communication. This we evaluate when we run RT we plot the timing of RT and use to shake and do all other activity that take max CPU usage and affects TCP/IP communication.
I am not sure whether this is a solutin but this should have given you an Idea about the scenario.
Message 2 of 8
(3,510 Views)
This for instance can depend on how you transfer data from/to the user interface you are "shaking".
Another (more) possible reason is that you are running components in the UI thread. By moving the window, you are "loading the UI thread" with additional computations hence preventing it to perform other tasks (e.g. calling into your DLL).
Norbert
Norbert
Expert: Geometry
Message 3 of 8
(3,508 Views)
I expect that Norbert is right. It's time to read about Multitasking in LabVIEW and move your CAN code to another execution system.
Message 4 of 8
(3,497 Views)
ok, I understand what you tell me,
but I have to implement in the UI thread.
One solution would be to add a inhibit time to the variables that are Into the UI thread. (eg, make the change of the variable if it changes and it is stable during 0.5 seconds) so small interference would be canceled.
is there a way to do it automatically?
I hope you understand me
thank you very much
Message 5 of 8
(3,489 Views)
Sorry, I didn't understand.
Another way to prevent you from interfering with the UI is
- Do not show the title bar
- Do not show any scrollbar
- Do not allow to resize the window
Thus you get a window with a fix position and no longer can "shake" any part of it.
Message 6 of 8
(3,481 Views)
I need to constantly change VI's because I have multiple VI's with control panels
I try to explain again:
I want that the global variable does not change until you take for example 0.5 sec changed:
0s-> IN: TRUE, OUT: TRUE
0.1s-> IN: FALSE, OUT: TRUE
0.2s-> IN: TRUE, OUT: TRUE
0.3s-> IN: FALSE, OUT: TRUE
0.4s-> IN: FALSE, OUT: TRUE
0.5s-> IN: FALSE, OUT: TRUE
0.6s-> IN: FALSE, OUT: TRUE
0.7s-> IN: FALSE, OUT: FALSE
Thanks.
Message 7 of 8
(3,471 Views)
Thanks.
I don't understand how it would help with your CAN problem, but does this do what you want?
Message 8 of 8
(3,436 Views)
