how change two picture with boolean control?
Hello
I want change a picture with another picture or change color of a picture with a boolean controler. is it possible?
how?
Best Regards.
Message 1 of 8
(5,078 Views)
Hi Behzad,
Do you want to switch between only TWO pictures or different set of pictures?
If former is what you want then you can use Case Structure and wire a Boolean Control with it. And if you want to change a picture every time you press a button then you need to use Event Structure which would trigger an event of changing picture and display it on front panel every time you press a boolean control.
Regards.
Message 2 of 8
(5,062 Views)
tnx NapDynamite
yes I want switch between only TWO pictures. but how can I show them in front panel? do u mean visible one picture when I show other one in case structure? or there is simple way to do it? how case structure can help me? may u explain more?
Message 3 of 8
(5,054 Views)
Accepted by behzad1
In this case using a Pict Ring control (from the Ring & Enum palette) is probably the easyest way if you don't need to load the pictures dynamically. To load them dynamically you can use a 2D picture control (from the Graph --À Controls palette).
Ben64
Message 4 of 8
(5,029 Views)
Place them both.  In the case structure use property nodes to hide/show them.
Edit:  this is what happens when I open a thread long before I actually type a reply.
Message 5 of 8
(5,015 Views)
Accepted by behzad1
Read an image file inside Case Structure and wire Vision Display outside of it.
Message 6 of 8
(4,969 Views)
You can customize a boolean control by replacing the standard images for true/false state with the pictures you want to show.
Message 7 of 8
(4,962 Views)
Hi
Thanks a lot friends
your responses really helped me.
Message 8 of 8
(4,917 Views)
