how can i print out the waveform chart?
  hello everybody,
how can i print out the "waveform chart". can i do it just push the button. ( example; stop button is stop the program etc..)
i checked the NI examples but i can't understand. i'm new to the Labview.
pls help me.
i added the my program
look forward your reply
regards from turkey...
Message Edited by hknmkt on 05-29-2008 04:15 AM
Message 1 of 47
(4,536 Views)
An easy way is to add the Print VI panel VI to your VI.  See the attached pic.
Jim
LV 2020
Message 2 of 47
(4,521 Views)
 hi jim,
thanks for your reply.
but i couldn't fix the wire 😞
how can i do??
pls help me..
hakan
Message 3 of 47
(4,508 Views)
Hi hakan,
you can also use the property node of your waveform chart and read a picture of it. Then you can use the Report tools to print the picture.
Hope it helps.
Mike
Message 4 of 47
(4,505 Views)
thanks mike,
i'm trying your way.
i wrote this program but it couldn't run.
pls show this program and say me pls, where is the wrong?
thanks for everything
hakan
Message 5 of 47
(4,496 Views)
Hi hakan,
this works for me.
Mike
Message Edited by MikeS81 on 05-29-2008 02:20 PM
Message 6 of 47
(4,491 Views)
Hi hakan,
This will also work.
Jim
LV 2020
Message 7 of 47
(4,486 Views)
thanks mike and jim.
jim, i'm grateful to u...
but when i run the program Labview is open the "send fax wizard"
how can i fix it?
last problem, can i save  the chart  in the pc just push the button. now, i can use the "export simplified image". but i want just push the button on the front panel.
hakan
Message 8 of 47
(4,480 Views)
Hakan,
The print report VI uses the default printer.  Do you have a fax/printer?  Also you can use the save report to file VI to save it.
Jim
LV 2020
Message 9 of 47
(4,473 Views)
    hi jim,
i tried the program but it's not running. When i run the program, it's print out without run the program 😞
i added the printed file.
hakan
Message 10 of 47
(4,461 Views)
