how can set window title programmatically
how to set the window title programmatically
for example the main vi i have a combo box  which stores some names
exp: abc
        bcd
        cde
then it will pass the data to another vi all the names use the same vi to display the data
i want the window title to be the name of particular name user selected.
 can anyone help me?
(9,851 Views)
Hi jeyanthi,
use a property node. connect the reference of the vi to it and select frontpanel-window -> title.
Mike
(9,848 Views)
can i get an example plz . thk u
(9,842 Views)
Hi jeyanthi,
attached you will find an example.
Hope it helps.
Mike
(9,840 Views)
thk u it helps
(9,832 Views)
