help
I am new to labview and I am having difficulty creating an array and writing it to a spread sheet. I have a for loop that generates 3 data values every interation. I would like to write these values to a 2d spread sheet with three colums. I attached a sample VI, but I dont know what is wrong. Thanks.
(4,002 Views)
Try something like this:
(Your main problem is that you start with an empty array and try to insert at column 1. This place does not exists. Start with index zero.)
Message Edited by altenbach on 03-26-2009 09:47 AM
(3,996 Views)
Heres a quick way to do it:
The cool thing about For loops is that they will auto-index.
So when you pass each of the 3 values out of the array, they will each build a 1-D array.
Each of these will act as a column, so if you use a 'Build Array' function, it will combine all 3 1D arrays into a 2D array.
Then use a 'Write to Spreadsheet File' function
Edit: darn, too slow Smiley Wink
Message Edited by Cory K on 03-26-2009 11:51 AM
Cory K
(3,986 Views)
Cory,
Your code would generate three rows instead of three columns. You would need to transpose for writing. This is the reason I was using "build array" inside the FOR loop.
(3,964 Views)
altenbach wrote:
Cory,
Oh, you're right, I didnt check which way the array was oriented. Oh well, nothing a quick 'Transpose Array' cant fix. Smiley Wink
Cory K
(3,960 Views)
... or simply wire a TRUE to the "transpose?" input of "write to spreadsheet file". 😄
(3,951 Views)
