‎10-21-2015 08:55 AM - edited ‎10-21-2015 08:56 AM
hi drek,
Gerd says its a labv7 problem
The only problem is: LabVIEW7 doesn't use an enum for this property. In this ancient version simple integers were used.
i quess dont know, need do look for anonther solution
No, you don't need another solution. You only need to create the correct value and wire it to the property node.
Again: read the context help for this property node to know which value you need to use!
What's your problem in reading the help?
‎10-21-2015 09:01 AM
think i understand now , if i use 0 nothinh happens, 1 the swtich is blocked, 3 the switch is blocked and grayed out ?
‎10-21-2015 09:05 AM
thx guys for al the patience
now just find out how to reset
‎10-21-2015 09:14 AM
‎10-21-2015 09:16 AM
nno did not 🙂 found it now trying to reset it 🙂
‎10-21-2015 09:29 AM
‎10-21-2015 09:30 AM
‎10-21-2015 01:03 PM
‎10-22-2015 01:58 AM
so i have to make a new property node with visible ?
