gray out switch
hi drek,
Gerd says its a labv7 problem
The only problem is: LabVIEW7 doesn't use an enum for this property. In this ancient version simple integers were used.
i quess dont know, need do look for anonther solution
No, you don't need another solution. You only need to create the correct value and wire it to the property node.
Again: read the context help for this property node to know which value you need to use!
What's your problem in reading the help?
Message 31 of 40
(3,703 Views)
think i understand now , if i use 0 nothinh happens, 1 the swtich is blocked, 3 the switch is blocked and grayed out ?
Message 32 of 40
(3,694 Views)
Gerd is right. Enumeration is a way of tagging a number with a label. Enum: Enabled , 0 Disabled, 1 Disabled and Grayed Out, 2 Set the input to Numeric Constant = 2.
Message 33 of 40
(3,693 Views)
thx guys for al the patience Smiley Wink now just find out how to reset
Spoiler
Message 34 of 40
(3,686 Views)
Hi drek,
Did you read the context help?
Really?
Message 35 of 40
(3,681 Views)
nno did not 🙂 found it now trying to reset it 🙂
Spoiler
:womanlol:
Message 36 of 40
(3,678 Views)
The context help, which you have been repeatedly told to read, tells you the numeric value that you can use. This is a trivial problem to solve.
Message 37 of 40
(3,667 Views)
Accepted by drek123
instead of 2 (Disable and Hide) at the beginning of the program, you are going to use 0 (Enable) at the end of the program to get it to come alive again. Right click the property node and choose "Change to Write" if you're having trouble writing to the property
Message 38 of 40
(3,663 Views)
Did you get your answer so we can solve this question?
Message 39 of 40
(3,641 Views)
so i have to make a new property node with visible ?
Message 40 of 40
(3,614 Views)
