generate voltage in myrio 1900
Hi guys, i was trying to create a constant voltage (1.25V) in labview using myrio 1900. I tried few times but still couldn't make it. Can Anyone help ?
Thanks in advance !
Message 1 of 8
(5,478 Views)
What did you try? Make sure you don't draw too much current.
Message 2 of 8
(5,470 Views)
Accepted by baoxuan
Hi baoxuan,
i was trying to create a constant voltage (1.25V) … using myrio 1900.
there is a +5V output on the MXP connectors: you only need 2 resistors to output +1.25V…
(You don't even need LabVIEW for this task.)
Message 3 of 8
(5,464 Views)
i try using analog input there but it is not working. I am new to labview. Please help .
Message 4 of 8
(5,458 Views)
Thanks for replying. What if I need to generate different voltage ? Where it could not be done using this method. Thanks in advance!
Message 5 of 8
(5,455 Views)
Hi boaxuan,
To output a voltage you should use an anolog output channel…
Did you notice that "Training" section in the header of this LabVIEW board?
You didn't ask for "different voltages". You asked for a constant voltage…
Message 6 of 8
(5,442 Views)
Hi guys, I am trying to generate analog output voltage in labview. Can anyone help me please.
Message 7 of 8
(5,448 Views)
Accepted by baoxuan
Start with the examples.
Go to the "Help" menu in LabVIEW, select "Find Examples", then in the example finder, go to the "Hardware input and output" category, "DAQmx" subcategory, then "Analog output".  There should be 7 in LabVIEW 2018; possibly different amounts for other versions.
Message 8 of 8
(5,422 Views)
