ft_prog utility eeprom
I am trying to program the EEprom of an ftdi ft2232D using ft_prog utility,I have  clicked on scan and parse and then went to usb descriptor string and changed the product description after which I clicked program devices but ,on clicking programming I get a message saying unhandled exception has occurred in your application.How do I resolve this problem?Thank you in advance.
(4,046 Views)
A few questions:
  • What did you change it from and too?
  • Does it work if you change it back to the origninal?
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(4,043 Views)
i don't know if i have understood your question but i have attached a power point file with the image of ft_prog utility,apparently the product description is USB serial converter....i want to change that to a generic description,,,lets say pippo
(4,035 Views)
I'm sorry but I cannot understand why you are posting to LabVIEW board: what exactly are you trying to accomplish with LabVIEW and what behaviour you are observing?
Bye,
Licia
(4,012 Views)
 sorry because now i realise this question is not meant for the labview board...thanks
(4,004 Views)
