formula node
Accepted by s.turino84
You really should add a dt input to state what your time step size should be.  And again, I would just keep this in the native LabVIEW.
Message 11 of 13
(1,056 Views)
yes ofc in the example I deleted the for because I put in the formula node (like in matlab) n=0:0.5:100 or something like that 🙂
the problem that i don't understand is the reason why it doesn't work with this formula. I mean my idea was to bypass the FOR.
Another thing why the A must not be an integer?
Message 12 of 13
(1,035 Views)
Formula nodes aren't the same thing as matlab.  They don't use the same syntax.  It doesn't have an array definition function like you are showing n=0:0.5:100.
You can put a For Loop inside the formula node.  Look at the help for a formula to see the syntax of the functions it supports.
Message 13 of 13
(1,028 Views)
