キャンセル
次の結果を表示
次の代わりに検索
もしかして:
error in/error out
Hello. I want to learn to manage the cluster error in/out. Attached there is the VI that I have created.
As you can see I think that I can handle properly the error out (I can modify the status/the string etc etc)...what I want to do (but I don't know how to) is modify the error in.
I mean if i get as input -1 I saw the message in error out but i want that also the error in change his status (boolean/string/code).
Can you tell me how to do it?
Thank you
0 件の賞賛
メッセージ1/4
3,769件の閲覧回数
Which error do you want in the Error In terminal.
If you want the Error Out String in Error In (where i dont find any logic) you will need to put the local variable of the Error In Control and connect it to the Error Out terminal.
0 件の賞賛
メッセージ2/4
3,760件の閲覧回数
Can you be a little more clearスマイリー 平静. I hope you can use the error constant for the type of question you have.スマイリー ハッピー
スポイラ
0 件の賞賛
メッセージ3/4
3,737件の閲覧回数
0 件の賞賛
メッセージ4/4
3,716件の閲覧回数
