format into string 16 bit signed integer
Is there any format specifier string for "Format into string", whereas the result is an I16 string?
My problem is when I use "%d" and the input string is 65535, the result string should be "-1".
Message 1 of 9
(8,216 Views)
Just convert to I16 first then scan to string
"Should be" isn't "Is" -Jay
Message 2 of 9
(8,209 Views)
Are you trying to get an integer out of an ASCII string (Scan from String) or turn an integer into a string (Format into String).  You title and question seem to contradict each other.
Assuming you are trying to scan from string, it looks like you need to scan into a U16 and then use a conversion bullet to turn it into an I16.
Message 3 of 9
(8,208 Views)
The input of the function is a DBL...
Message 4 of 9
(8,205 Views)
Then use Jeff's code as an example of what to do.  You just have a double input instead of a U32, U16, etc.
Message 5 of 9
(8,200 Views)
I did it... the result string is 32767 😞
Message 6 of 9
(8,190 Views)
Accepted by mitulatbati
Actually you need two conversions
to do that from dbl  (LabVIEW Minutea that might bite you some day:  Float to int retains sign)
Message 7 of 9
(8,186 Views)
Hi mitu,
then combine your approach with others shown before:
Message 8 of 9
(8,185 Views)
there are some other solutions, in each case the result=-1:
Message 9 of 9
(8,138 Views)
