format conversion
I am new to labview i am not able to think how to do the conversion,
i have a number but it is in string format but i am trying to get the same number in number format
like +3.999,-3.9999 but they are in string format can some one help to get these number in number format.
Thank you
(3,194 Views)
Look at "Spreadsheet string to array" if multiple numbers are as list "3.999,-3.9999,..." or at String to number functions if each number is a separate string.
(3,171 Views)
Check out the attached PNG.... there is a whole section to help you out with that... you can even specify which type of number you want to convert to.... I recommend the first in the second row.... Decimal String to number 🙂
(3,166 Views)
Thank's for the help
(3,150 Views)
Once you've dabbled a bit using the individual string conversion functions, take a look at Scan From String and its inverse, Format Into String.  These can be used as parsers, capable of taking something like "Weight = 32.5 kg, Height = 57.8 cm" and returning 32.5 and 57.8.  I no longer use any of the Number/String Conversion functions, just Scan from String.
(3,133 Views)
Thankyou Bob_schor sir for help i really appreciated that letting me know something new i can do.
(3,096 Views)
