find frequency from input signal
The way I would do this is to feed the signal into two bandpass filters centered at your two frequencies of interest (in parallel).  If you square the output of each filter and then detect a DC signal above a threshold determined by testing (for each filter), you should be able to tell which tone is present.
Randall Pursley
Message 11 of 13
(2,170 Views)
Can you post that VI?
Eric
Message 12 of 13
(2,161 Views)
Message 13 of 13
(2,147 Views)
