file
hiii,
i must saving a element of array of cluster in a file, and increment the index of element and written the data in a new file.
i don't have a idea??
Anyone have a idea ?? or example to see?? or link??
thank's in advances
(3,484 Views)
Look at Index Array, and Unbundle Cluster functions.
Use shift registers to store values between loop iterations.
Your question is not very clear.  You would need to post an example of the data structure you have as well as a clearer description about what you want to extract from it.
I would recommend you learn more about LabVIEW from here. How to Learn LV
(3,480 Views)
perhaps i don't be clear. i can using a loop and shift register, but i don't have clear the structure of written in the file .txt.
you have understand??
thanks for the response
(3,473 Views)
As mentioned, post an example VI that you have written up so we can understand what kind of data you are working with.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,453 Views)
this might help it goes along with what raven said:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,443 Views)
