fastest conversion from DBL to U8 array
I have to convert a monster array of doubles to an array of bytes.
So first I have to convert (type cast) all the DBLs to array of bytes of 8 elements. The result byte array has a size of 8 x size of Double array.
This takes sooooo long... Is there a fast way to do it?
(6,450 Views)
Accepted by mitulatbati
Hi mitulatbati,
have you tried:
- to use pure G functions instead of formula node?
or, even better
- discard the whole FOR loop and directly typecast the DBL array to an U8 array?
(6,438 Views)
  Instead of using array functions ,use split number vi..See the attachment..
Thanks and regards,
srikrishnaNF
Srikrishna
(6,431 Views)
Hi srikrishnaNF,
what are you doing there?
First you typecast to an array of U32 (I suppose), then split the U32 numbers in the loop to build a 4-element-U8-array, then autoindex those U8 arrays to form a bigger 2D array, then reshape that one to get the resulting 1D U8 array...
Why not directly typecast to U8 array?
I think I will post this thread to the RubeGoldberg-collection Smiley Wink
(6,425 Views)
Hi Gerd,
yes I have tried the pure X G function, but the speed is the same.
Typecasting a DBL array direct to a U8 array works fast!
MB
(6,412 Views)
Hi MB,
direct typecasting works fast because LV doesn't need to shuffle any data from one place to the other... Smiley Wink
(6,389 Views)
GerdW wrote:
Hi MB,
That is not really true. Typecast in LabVIEW always converts data into big endian form. For doubles this means inverting the byte order of every double but this is indeed still lighting fast in comparison to taking apart an array and copying it back into another array.
Rolf Kalbermatter  My Blog
(6,314 Views)
