failed to connect target
Is it connected on MAX?
Message 11 of 23
(4,196 Views)
Yes, it is connected. All status of embedded controller is listed on MAX info page.
Message 12 of 23
(4,193 Views)
It works now.
The issue is caused by target not installed.
I am a newbie to Labview RT:)
Message 13 of 23
(4,186 Views)
I'm sorry.  Can you  clarify what you mean by "target not installed".  Do you mean in MAX or the Project?  What steps did you perform to resolve the issue (assuming it is still resolved).  I have a similar issue that occurs sporadically.
Message 14 of 23
(4,043 Views)
Hansel,
Could you describe your issue in more detail? It seems like the topic of this post was a consistent issue. Are you able to see your device in MAX and configure it, but unable to connect to it in your project?
Austin
Staff Software Engineer
NI
Message 15 of 23
(4,025 Views)
We are having the same error as we try to connect target. After getting this error as we connect our target from MAX the system status changed from running to Safe Mode (Improper Installation). After this, I am unable to update the firmware of the target even unable to uninstall the software too. Currently, our 4 boards are working due to this error. Please go through attached documents.
Message 16 of 23
(3,258 Views)
Can you clarify what you mean by improper installation? Where you having issues with MAX during the install process?
Message 17 of 23
(3,241 Views)
The same question I want to ask what is mean by improper installation...??
Initially, as we installed the software using NI MAX, the status at MAX was Running Mode. Now as  the target connected through Labview the error popup "Failed to connect target"  the status at NI MAX now changed from running mode to safe mode improper installation. Now I am unable to resolve this problem even I tried to uninstall the software but it is restraining with an error message attached below.
Message 18 of 23
(3,236 Views)
Can you please be more clear with what exact software you are trying to uninstall and what steps you took to do that? Also can you please take a screenshot of this improper installation Max Status. I'm not able to clearly see that in your screenshot.
Message 19 of 23
(3,229 Views)
Ok, I am going one by one
Image1 - As I tried to connect target from LabView.
Image2 - Target status in NI MAX.
Image3 - As I tried to uninstall the software from the target.
Image4 -  Error during uninstallation of software.
Image5 - Then I tried to update the firmware.
Image6 - Error during the firmware update.
Above problems are running with four sbRIO 9627.
Message 20 of 23
(3,220 Views)
