failed to connect target
The RT target I have(PXIe-8840) is showing connected on MAX and is loaded with Phar Lap OS 13.1. Currently LabVIEW Real-Time module, Network Variable Engine and Network Streams are installed on RT target.
I am trying to load the sample tutorial file onto the RT target. I got the sample tutorial file from Find Examples->Tool Kits and modules->Real Time-> Tutorial
Labview is not able to communicate with the RT target when I try deploying or 'run as startup' the RT target VI. Capture.PNG
I essentially followed the steps on this manual: http://www.ni.com/pdf/manuals/371375c.pdf and am getting stuck on page 10 step 2.
Please kindly suggest what the error could be.
Ankur
Message 1 of 23
(12,562 Views)
Did you configure correct IP address in your project?
Message 2 of 23
(12,543 Views)
Through max i configured and installed the appropriate softwares on target. Next, I right clicked and entered the target IP address for RT target - so that (0.0.0.0 in figure below) was replaced by the target IP address.
Message 3 of 23
(12,539 Views)
So do you get the error message when you try to connect to the RT by right clikcing the Target in project?
Message 4 of 23
(12,535 Views)
Yes. And exactly the same message(one in the 1st figure in my earliest message) pops up also when right click to contents of build specifications to run at start-up.
Thanks!
A
Message 5 of 23
(12,531 Views)
Ok, please create a new project and in that go to  "Targets and Devices" and try to add you RT system which is existing. This would make sure that the project is able to communicate with the RT. Once it is added then try to connect with it, if it is successful then you can proceed to deploy the code into your RT.
Message 6 of 23
(12,528 Views)
I have the same issue. I follow your advice and create a new target from the detected one.
But still not working and fail to connect.
Message 7 of 23
(12,493 Views)
Make sure that all the softwares(the 3 softwares) installed on the target are of the same version corresponding to the labview you have(for 2014 14.0 and for 2015 15.0.0). After you build and deploy the target VI, run the RT target VI and then run the windows-main VI.
Message 8 of 23
(12,490 Views)
Is it working for you?
Message 9 of 23
(12,475 Views)
No, very frustrating!
I have updated my Labview and Real-Time module to the same version as my MAX, which is 15.0.
See screenshots:
Message 10 of 23
(12,454 Views)
